Trans Line Pressures
'92 350 extended cab interior trim
92 motor in Vt
In general... what is the ideal line pressure of a stock A518 auto? And in general which port is the best to use? Front, middle or rear test ports? I'm reading the middle and then check the others to see how they compare. They should be close.
Should the line pressure be checked in neutral or drive? RPM's should be ???
I'd like to check mine and make sure I don't need to adjust it up or down.
First advice is to get a factory service manual!!!!
Front port is 2nd. middle is line--check in drive. Rear is manual 1st and reverse.
