Trans locks up after shifting into 3rd, then hard shift into 4th.
Transfer case seal leaking
Transmission Rebuild/New Transmission
So, just had my Trans rebuilt at ATO. Shifts nice and firm, etc. However, it shifts from 1st to 2nd to 3rd, then locks up, then into fourth--really hard. Jim says it is a program issue and needs to be flashed...
Also, when passing, it rev's really high and hits governor, trying to go into 2nd. Won't go into 2nd until I back off pedal. (this was happening before re-build)
Any thoughts?
5.9L 2005, Ram 3500 Laramie, Long-bed, Crew Cab, 4WD, RBP Exhaust, ATO Super Heavy Duty Trans, Mag Hytec double-deep pan, Edge CTS (I run in Tow-1).
Unfortunately, there is no flash to change the shifting algorithms in an 05 without losing efficacy. Part of the problem when building a VB is getting that 3-4 shift to be sooth and firm instead of harsh, Has a lot to do with the TC also, triple disks are notorious for being harsh on the pulsed 3-4 shift.
The way the programming is setup you cannot go WOT throttle under about 65 mph or it will try to downshift to 2nd and lose speed. You have to heavily modify the VB or train your right foot not to do that. After about 3/4 throttle and under 65-70 there is nothing gained there anyway, fueling won't be any more until speed and rpm gets high enough.
