This weekend I'll work on replacing the 727 in my '90 D250. I've only replaced trans on my MB diesel before and don't have that much experience with American cars. Any pointers ya'll can give me, things to watch out for, or tricks to speed things up?
I've never even disconnected the drive shaft on an American vehicle before
I'm used to German over engineering.
If there are any critical torque specs please post 'em if you known 'em since I don't have the shop manual yet.
I figure I will need to unbolt the torque converter from the flex plate by turning over the engine. Should I be using the ring gear and a pry bar or some of the bolts on the front crank? The barring tool is just about useless on vehicles with auto transmission - the heat exchanger seems to be in the way?
Once the TC bolts are free, the cooler lines, linkage, wires, etc and driveshaft are free, I can unbolt the bell housing bolts/starter and then (transmission jack supporting trans) slide the unit back and out from the engine?
What is the torque on the flex plate, torque converter, and any torque for the seal cover?
Thanks a million,
Brian
Thanks a million,
Brian
