valve body including transfer and seperator plates
pump 15-20 percent more volume and drainback o-ring
front clutch retainer and reare clutch retainer
geartrain
o/d planet
more o/d clutches in 03/04 back to 47 style in 05
front band apply lever and thicker band strut
changed rear clutch teeth count from 41 to 92
torque converter is the same part # as 47re
yes the 47re would fit in a 99 but electronics were changed in 47's in 00
and even if you put 99 electronics in a 48re the 99 pcm may not accepth the boost pressures the 48re valve body exhibits.
In other words, many pieces from a 48 fit in a 47, why would you want
to put the whole transmission in.
