Trans. Temp Guage - WHich one to buy?
New intake letting stock turbo spool too fast?
Valve cover Supplier?
I have an '03 and '06 CTD. Which brand/model transmission temp guage is best and most closely appears like stock. Also, where is the temp sensor located? Drill a hol in the transmission pan? or is there an easier way.
Thanks!
Andres, you should fill out your truck signature so the guys with the knowledge can help you more readily. I am assuming that you have a auto. cause you mentioned a "pan".
I really like my Dipricol guages in my 04.
My Isspro gauges are an excellent match for the '06 dash gauges. I mfg. a sort of saddle tee to strap on the output cooling line of the transmission. It works exceedingly well and didn't require drilling the pan or opening the lines. Geno's now sells a somewhat similar device for about $40. It is just a most elegant solution to the issue.
Dan
Dan
I have been running Isspro EV Series gauges 4 -1/2 yrs no problems. :D
