Just had the trans fluild and filter change(not a flush) 30,000 miles. second drain/filter change. After the change, I noticed fluid temps are higher than usual from before change. Temp measured in outflow coolant line. Prior to change temps would almost always be below 150 around town, on xway even lower. Since change temps are consistantly in the 180 range.
I am under the impression that there is a valve associated with the filter.
Question is: are these temps in line with what others are seeing. Is there a restriction in flow with new filter or was there an issue with prior filter set up.
Thanks for your input.
