I have about 145k on my stock auto, the only thing I've done to it is add a 3 pos. lockup switch mounted an inch below the turn signal lever. I drive it by the switch 100% of the time. I also went to Tractor Supply, and got a 10 micron, spin on filter % block for hydraulic systems, mounted it on the little cross member behind the front bumper, and spliced it into the rubber line going to the hot (driver's) side of the transmission cooler. It also has a probe port in it, and that's where I take my transmission temp. This is in the line coming from the TC to the cooler, & this is were you'll find your hottest temps, not after it returns too the pan, already cooled. The block & filter are about $20. 00, and have 3/4" pipe fittings. It flows 20 gal per minute, and is commonly used on wood splitter return lines. I put it on when the truck was new, have had no problems with it, and it keeps the fluid CLEAN!
