Hi, can someone tell me which trans cooler line is the "out" line? Is it the front or rear line on the transmission? I think it is the front one which then goes up to the coolant heat exchanger and on to the front air cooler. I've read that there is an trans temp sender adapter available from Dodge, but what is wrong with cutting, flaring the 1/2" aluminum line and using a JIC flare "T" for the sender? Thanks.
Todd
Todd
