Man this is awesome!!! Thanks guys!! This is what I love about this site, so many good ideas and answers. When I first looked at the pictures, I hadn't a clue to what I was looking at because I hadn't even looked under my truck. Then I read ALLNEW2ME's post on how he made a clamp to go over the half inch line I thought to myself. Oh? This thing has 1/2 inch lines? Well excellent because I have these really cool compression fittings, that have a double ferrule, that are for 1/2 inch stainless steel tubing, are all stainless and good for pressures above 350psi. So I proceeded to find me a Tee fitting and I cut the bottom part of the Tee off, cut a 1/2 inch stainless steel pipe coupling in half and tig welded it to the Tee. So now all I have to do is cut a part of the line out with a tubing cutter, install my fitting and I should be in business! So it will basicly be just like the massdiesel one but homemade! And I plan on installing it in the same locating as that one. Once agian THANK YOU all for all of you input and great help!!!
Thanks,
Snoxracer
Dustin
