Two days ago I pulled out of my driveway and my truck didn't shift into 2nd.
I double checked and the selector was in drive. The motor tached out at 3200 but it would not shift unless I let up on the throttle. I will go into second but you can't speed up without it down shifting. .
I have noticed once I get up to about 30 mph it seems to stay in second. And pulls fine.
All other auto trans functions appear to be working. Shifting up and down are normal.
I had trouble a couple years ago with the shift transducer / shift solenoid.
I replaced them and she's been fine ever since.
I replaced both batteries yesterday after she would not crank or start. So they should be good.
Using some advice found here, I have replaced the TSS Transmission Speed Sensor. (Today) But she is still acting up. There was some very fine metallic dust around the tip, and a little bit of fine shavings on the end of the tip.
I will admit I have never adjusted the bands.
I have 241400 miles, Stock motor. Never off roaded, or abused. Other than driving her like she was made for.
I'm asking for tips and advice before I drop her off at a trans shop. I never trusted the dealer, and I've never used a trans shop.
Thanks guys. I'll be on here all night if that's what it takes.
Dave
Dave
