Ever since I had my trans built with the suncoast converter,ATS valve body,all the other good parts ( By a Authorized ATS dealer) the trans wont shift out of first gear when in 4 wheel drive. Since then I installed the noise filter to correct the gear hunting problem asociated with electrical noise from the alternator, It's been back to the shop and diagnosed with all available scanners and no cure yet. It will shift up only if I exceed 25 MPH, which is usually at redline around 3200 RPM in 4 low. It seems the trans is not comunicating with the computer, at least that's what I've been told by the tech dept. at ATS. Does anybody have a cure for this issue ?
98. 5 Ram 3500 4x4 sport,Auto trans,3. 54's autometer,sport comp pyro,trans,boost,electric fuel press. w/snubber,warning light/chime. edge comp drag box,2nd VP-44 inj. pump,carter pusher pump,dual fltr. amsoil. Suncoast converter,valvebody,Built by Inglewood Transmission,allum trans pan, Bilstien shocks,westin bars,push bar,custom 5" exhaust,BHAF, Silencer ring is where It's needed(at EX'S House).
