My son had the truck out for a run on Saturday and it quit. Just quick. Luckily he was able to coast into a gas station. The engine would turn over but no "fire in the hole". Had it towed
home to work on it but I do not have any pressure gauges. Thought the batteries may be the problem, in truck since new, as I had to recharge them. No go. Did not see any codes but the
"check engine" light was on. Dealer found that the transfer pump was shot. Replaced under warranty . Truck would still not start. The injection pump had no output now. This to is being replaced under warranty .
Tech said strange that there were no codes but he has seen that before. He figures the transfer pump went out some time ago and the injector pump was taking up the slack until it just gave up. Will be getting a fuel pressure gauge now. Has anyone else had this problem? Truck has 141,000 Klm on it. I hope to get it back real soon. Any suggestions for a good fuel pressure gauge setup? Should I monitor the "OUT" side of the fuel filter or the "IN" side?
