Details here: TDR Privileges
2018 ram 2500 with manual shift case. Very hard to shift to low range. It is automatic trans. diesel engine It will shift to 4 wheel hi, no problem Need help.
Free drivetrain. Neutral, foot off brake. Sometimes requires gentle drive to reverse then neutral to ensure the driveline is totally unloaded. Then it’s still stiff. I use 4lo regularly and it’s still stiff after 100;000 + miles.
Check the shift linkage before you go any farther. See my post. Read the second from last posting by Ron. He provided the factory instructions. Takes 2 minutes.
