Archived transfer case dissasembly
Archived Can't pull codes from 98.5
Archived help superchip/will not start
Can I take off the tailshaft of the transfer case in my truck to check the status of the c-clip without any replacement gaskets? if I need a gasket can I get it somewhere on a weekend? thx
Got it apart but the c-clip looks ok :confused: what else might cause a bang/grind noise from t-case area? only happens occasionally when there is a load on truck. but its a scary sound.
I had a horrible sound coming from that area and it turned out to be the U-joints in the front drive shaft. Good luck!
looks like the transfer case is shot... found a piece of melted plastic in the oil when I drained it and the oil was burnt. ordered a new t-case from transfer case express.
