Engine/Transmission (1998.5 - 2002) Transfer case oil ?
Engine/Transmission (1998.5 - 2002) HTT SP66/14 Turbo?????
Hello to all, Little bro has an 2000 s/o w/6 speed and was wondering what you all have had sucess with in the trans case. Unsure if these have the same requirment of atf+4 like my 04. 5?
Thanks in advance,
Tyler
ATF is definately sufficient but there are better choices.
My favorite is Royal Purple Synchromax. Synchromax is a light weight oil about the same viscosity as ATF. I've run synchromax in the xfer case for 5 years.
I put Amsoil ATF in my transfer case.
Stuff that came out with only 42k looked pretty nasty. Definitely a good idea to change it.
Amsoil ATF here as well. Not sure how much better Amsoil ATF is then ATF+4, but I do know that I added more oil to the T-case, then came out.
