OK folks, I understand completely why, when you turn tightly in 4WD, you get that occasional slip of the tires on the gravel (no front-to-back differential action).
So, what I would like to understand is, with these Center Axle Disconnect front axles we have, why does it still seem to do the slip thing AFTER you shift it to 2WD, but before the 4x4 light goes out (CAD disconnects)
Sure, at this point you still have the CAD connected, but the transfer case should be disconnected, right? Thereby allowing front and rear drive shafts to turn independently, right?
Or is it just that only MY truck does this, cause there's something else wrong???
-cj
-cj
