Engine/Transmission (1994 - 1998) Transfer Case Power Distribution
Engine/Transmission (1998.5 - 2002) P7100
Is there a difference in power distribution in 4 Wheel Low or High Lock.
Example: In 4 wheel high either the front or rear tire lost traction you were stuck and In 4 Wheel Low Lock the driving power was forced on both axels even if front or Rear lost traction.
I thought the only differance between High or Low Lock was the gearing and not distribution.
Thanks for your time.
Rex McKinney
Transfere Case
You will have equal power to the front and rear in 4 high or 4 lo, unless you have something wrong with your transfere case. Oo.
The only difference between High and low Lock is Gear Ratios.
The power distribution is the same.
Feels good to win.
Thanks for the information.
Rex McKinney 95 2500 Auto
