what is the switching means for the pump to turn on and off. ? i mean there is not always 12 volts to the pump when i turn on the ignition or should i say the pump doesn't build pressure when the igniton switch is turned on . i am seeing my pump build pressure to 16 # then go to 5 ,4,3, # when driving then . if i restart the engine it will go to 16# . and most of the time stay there . i am getting some erractic readings and trying to find out what is going on or diagnose the erractics. ? this transfer pump is only about 15000 miles old/thanxs tdr
