Engine/Transmission (1998.5 - 2002) transfer pump runs with key off
Engine/Transmission (1994 - 1998) wiring gauges to dimmer switch
2nd Gen Non-Engine/Transmission abs and brake light on??
99 dodge ram the transfer pump runs for about 45 sec after the key is shut off. i thought maybe it was the ignition switch failing so while the pump was running with switch in off position i unplugged it. pump continued to run. chrysler manual claims the ecm is the only control for transfer pump. ecm tests ok
