Transfer Pump
Bio VS vulcan fuel lines
Hydrogen injection?
Anyone know where is the place to get the best deal on a transfer pump(connect to your battery for power) ? Thanks to all who respond
transfur pump
hello
what are you pumping and how much are you pumping
I have a dixon pump that will pump 15gpm of LIGHT OIL but I use it for pumping cold used veg oil its only pumping at 10 gpm. there a good pump but you will want to sit down when they tell you what they cost. a hand barrel pump worked for me but I would get tired fast.
cj hall
I've been using this pump for over a year and a half and its still going strong. Its moved over 8000 gallons of WVO, diesel, and Bio-D. It isn't cheap, but it works well. But it works best on 24 volts. It'll do just fine on 12 but it is slower, of course. I'm lucky in that I have access to 24 volt aircraft batteries that are no longer in service. But 2 regular ol' 12v batteries in series will do just fine.
J.
