Transgo ideal setup?
I tell you, I may have hit upon an ideal setup for my dodge.
I installed the transgo 518-TFOD KIT.
I also opened up the 1-2 and 2-3 orfice for firmer shifts.
I also opened up hole for line pressure. BUT COMPROMISED since I had stock seals, I did not open to the largest diameter, went 50% of max as I recall.
I am currently running Valvoline Maxlife trans fluid. Mercon/dexron. It works very well, but does have a firm shift, that may be too firm for this heavy a truck. Would not think a minute of it in my old 3400lb cuda. But my Dodge is twice that. Doubt that the transmission would be harmed, may result in shorter ujoint lifespan.
I also tried it with Amsoil Universal, and this fluid being more slippery with this transgo tuning level seems ideal.
shifts are lightening fast (1-2 of course being the best) and finger snap fast, but smooth, no thunk.
2-3 is softer than i like, not as quick. I will be spending tuning time with it. This is where that front band has to engage, front clutch pack engage, and rear band (rev-1st) release. Always 727 weak point. Hard to get perfect. It is 80% quicker than before.
To summarize, the transgo kit, with shift orifices opened and Amsoil gives an almost perfect shift.
