I used the three gauge A pillar mount of molded plastic or some synthetic material in a color that almost precisely matches the OEM interior colors. I used the identical setup for two years in my '06 then transferred the whole setup to the '08.
I happen to like the A pillar mount real well (all three Dodges I've owned have had one) but some prefer the dash or steering column mounts. I find the A pillar mount very natural to glance at without moving my eyes far from where I should be looking and also find the guages easy to read with my old eyes in daylight or nighttime driving.
It may simply depend on personal preference, driver height and driving position, and whether he also uses a dash mounted GPS. My guess is Geno's sells more A pillar mounts than any other but you might ask them.
Yes, I do use the clamp on temp sensor on my current truck. Nobody makes a deep pan with a temp sensor fitting (and apparently a deep pan is not needed) for an Aisin so I use the clamp sensor on the hot cooling line. It seems to read pretty accurately. I used the pan sensor on my previous '06 w/48RE because it had a Mag-Hytec deep pan w/fitting.
