Transmission was accidently shifted in 2 insted of drive in the supermarket parking lot and the transmission jumped between 1st and 2nd gear very hard, so hard the whole truck would shake. Took to dealer and after 5 days problem solved with some kind of valve changed. Had to wait on parts because of the large problem with this valve failing as the dealer told me.
I never use 2nd, just 1st when I pull the boat out of the water. Put your trucks in 2nd and drive it around the parking lot just at idle speed, you will know if somthing is wrong.
bish
bish
