Here's one for you oil experts.
What other grades(not brands) of gear lube can be used in the NV4500?
Factory calls for 75W-90
What would happen if you used 85W-140 in it?
Also, can the rear end use the same grade of gear lube used in the transmission, or does it have to be the 80W- 90?
