Can anyone in MO recommend a good and honest 48RE rebuilder, preferable in the south-west corner of MO?
An old friend of mine who lives in Shell Knob, MO has an '06 Ram 3500 srw he bought new. He has serviced it properly and regularly for the 150k miles he has driven it and never abused it. The truck has pulled a moderate-sized fifthwheel trailer much of its life and just returned home from a trip to Alaska pulling a large Airstream. On the trip my friend says he had to make one long pull at low speed in first gear on about a 6% to 7% grade due to construction. He said his gauges showed the ATF reached about 220° on two separate occasions. After that long slow climb he began noticing a slow and weak one-two shift problem.
The problem he is concerned about as I understand it is what he perceives as a slow one-two shift with apparent slippage or flare. He says that once he allows the very slow and soft shift into 2nd and gains some speed he thinks the torque converter locks and then the transmission seems to shift normally until he takes off from a stop again.
Information and advice will be appreciated.
