The Cable that runs from the injection pump to the Transmission I have heard is supposed to be adjusted right? I wasn't aware that these needed adjusting. Is there a way to adjust this and if there is how do I do it? Thanks
For a starting point, set it so there is no slack at idle. Then you can fine tune it from there. It should have a white locking device that will need to slide sideways to unlock it.
I remove the cable from the bracket to get to it better.
