Hey guys,
I have installed a water assisted cooling system on my radiator area and realized that it would work better if the fan was on to help pull the misted water through the radiator grids. At this point, I would like to add an electric fan to the trans cooler to help keep things cool while running steep, slow hills and was wondering if any of you have done this to your rides. What fan will fit and did you push or pull the install? Do you think a larger radiator is necessary or just more air flow?
Or, is there a way to manually activate the current stock fan?
Thanks,
Steve
Thanks,
Steve
