What are ya using and can I get it from NAPA, SUMMIT, JEGS???
Looking for something easy and cheap, (if there is such a thing)!
Originally posted by rweis
I took out my transmission one way check valve and only have a transmission temp problem when I back up my 5er for more than about 3 minutes. The fluid flow is about double I think without the one way check valve and one less critical part ot worry about. Bob Weis
Once when I asked BK about the check valve he said he does NOT automatically remove it. . He said the flow would be about double vs with it. Bob Weis [/B]
Originally posted by TowPro
thats a good price on the B&M cooler, I think, have not priced them. Is this the one with the larger lines I read we need to use?
Originally posted by fortunate1
I also disconnected the OEM cooler that "cools" the ATF with 190 deg. radiator coolant.
