Currently stranded in Mesquite, NV for 5 days. Transmission ate itself up. I'm replacing it, but need to put in a new check valve in the cooler line as it appears that was the cause of the failure. It's located in a transmission cooler line. I've heard it called a check valve, a ball valve, a cooler line valve, etc. No schmatic I've seen shows the valve actually inside the line. I've tried dealers, etc. , and no one can seem to identify the part. I need an exact part name, and/or or a part number. This is OEM, and appartently can't be bought aftermarket. The part has to be replaced with a new one or the transmission warranty will be voided. Otherwise I would just remove the valve from the line. Any help would be appreciated as I'm 1200 miles from home.
My signature will let you know the details.
THX, Skip
THX, Skip
