Iron Duke II
I ordered a transmission cooler line set to replace the oem lines from and to the 47re that have been weeping fluid at the crimp fittings near the transmission cooler. https://powerdrivendiesel.com/install-transmission-cooler-line/
Realizing it is likely unavoidable, would there be any guidance on the best way to remove the old lines including the output to and from the heat ex-changer with the minimal amount of fluid loss and mess? I have no lift. The trans pan has a drain plug, should I just drain system to start?
