HI All,
I am going to be towing daily with my truck this summer (lawn care... . total weight pulled is 3450 lbs)... . To make sure the transmission is cool I installed a B&M deep transmission pan and will be installing an aux transmission cooler..... I realize that the factory aux cooler is under the bed but a friend at a trans shop says he can put one in front of the radiator / intercooler where it will get better cooling because of the better location for ram air... ... I don't think he realizes just how little room there is BUT assuming he can get one to fit there, would this adversly affect the inlet temp for the engine since it would be in front of the intercooler?... . I know the goal is to have cool air for the engine but my other trucks have the trans cooler in front of the AC condensor with no ill effects?..... What do you think?... . I kinda lean towards putting it under the body but up front would get the best air for cooling BUT then again putting it in front ove everything would raise other temps too..... Help!... . or maybe I'm worrying too much?
Thanks in advance for your help and opinions
Andrew
Andrew
