transmission Cooler recomendations
How to install Fuel Pressure Gauge
Heads up for Edge owners
Which transmission cooler would work good on an '03 4x4 auto. I've already got the oversized aluminum pan; and when I tow a 10,000lbs trailer in 90 degree weather, the temperature runs at 210. thanks
Personally, I would get a modified valvebody. Maybe a better torque convertor. The modded VB will improve oil flow through the transmission, including the lube circuits. With 10k behind you, it should be doing a better job of cooling. I have the stock oil pan and only the stock coolers on my truck. Having a Goerend Brothers transmission, it runs quite a bit cooler than my stock transmission ever did. Only time it goes over 200*, is when backing up and the tc lockup clutch is not engaged.
Be carful about restricting the flow of the trans fluid better off leaving that part alone . Probably void the warranty.
the valve body from BD runs like $400 plus I don't know how much the labor will cost. Seems like a nice product to have.
