transmission Cooler
Would you do it?
finally some respect from my ford drivers
I have a 99 Dodge Turbo and just put in a transmission temp guage and from what I saw I didn't see a transmission cooler or I don't know what one looks like. The lines go to a tank of some sort but nothing to the front of the truck. ANy help???
The transmission cooler is located in front of the radiator on the drivers side. Welcome to the TDR. Lots of good info and well worth the $$$. Have fun. BE ADVISED!!! This stuff is addicting #ad
98. 5 3500 SLT Quad Dually 4x4. 3:54 Auto, Waterfall Blk on red. Custom dually flaps, Rhino lining, All acc's w/leather, Muth signal mirrors, Catz MSC's, 55watt back up lights, Optima Red Tops, 80/100 head lights
BD exhaust brake, Banks EGT/Boost/Temp gauges, Mag-Hytec DC&TP, SS bug screen and fender trim,SS Stull diamond line running boards, SS 4" turn down.
My Dually
Thanks, I must look like a nerd but I failed to follow the other line from the tank. I don't know what it does?
The tank on the passenger side of the engine cools/heats the transmission fluid with the engine coolant. My truck also has an air cooler for the transmission in front of the radiator, both coolers are piped in series,(goes through one, then the other then back to transmission. ) I assumed they all had two coolers. I have the towing package. bg
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Rancho 9000s, bug shield and window vents, black vented 5th wheel tailgate, 110 gal. aux. fuel tank.
