In '97' shortly after I purchased my truck there was a lot of talk about failures in the automatic transmission cooling system on some Dodge Cummins trucks. As I understand it, Dodge took some action in dealing with this problem -- maybe a recall? I asked about my truck and was told not to worry the defect was fixed before the '97's' cam out. The alleged problem (as I remember it) involved the quick disconnects in the transmission fluid cooling lines. According to the story being told: All or part of this coupling was made of a plastic that could/would fail at high temperatures it encountered, resulting in loss of fluid and failure of the transmission. My truck was manufactured late in the 1997 production year has two couplings in these lines that tie the steel tubing (mounted on the engine) to the hoses that connect to the air cooler located in front of the radiator. These couplings are made up of two metal (slip fit) pieces, which are made liquid, tight by an “o” ring and latched together with a plastic snap device. I have taken these couplings apart and examined them for evidence of damage or defect. I found nothing of immidate concern and there has never been any sigh of a leak at this point. This truck did however experience a connection failure in these lines when one of the fittings connecting the hose to the water to fluid cooler cracked and dumped several quarts of ATF before I caught it. I've not read anything about anyone else a similar problem and considered it an isolated failure, but am starting to wonder .
My son has a ‘94’ model (which he purchased new) and has never been contacted by Dodge concerning this alleged connector failure. In fact he contacted the dealer and was told that no such problem existed and that there was no service bulletin or recall involving the cooling lines or couplings in those lines.
Again I wonder --- Sure was a lot of smoke --- and Dodge says "there was no flame" ???
I’m looking for information from anyone with knowledge of a Dodge service bulletin or recall involving failures in this system and/or comments from anyone with first hand knowledge of failures of the sort/s noted above.
Thanks
George Oakes
Thanks
George Oakes
