having transmission replaced today, and while it was out, they removed the check ball completely, and also noticed that two cooling lines were leaking at the crimping points near the fittings. now they were not leaking enough to drip, more of a sweating per se.
heads up, as these are the factory cooling lines. we are replacing them with new lines (going to an aftermarket fitter)
also i am replacing the fluid with amsoil atf +4, and mag hytec transmission pan. short of a new valve body, this thing should be damn near bulletproof now.
will pick up the truck later amd let you know.
oren.
oren.
