Transmission/Differential cover gaskets
Drive line vibration
Insurance & inspection differences for CC's?
'05. 3500, 6-speed standard, two-wheel drive. I'm changing the transmission
and differential lube. Am I correct in assuming that the cover or access
gaskets should be replaced? Thanks again for your help.
diff gaskets are reuseable if not damaged. they are rubber coated steel. .
the pto covers on the transmission are just silicone. . they need to be remade once opened up
