I was givin a failed transmission(which was a new service unit)D/C- You guess it, out of warranty
he had to buy another, I pulled the top off LACK OF LUBE. Where did it go???????????
Might add this was in under 15k.
Also bad maintanceAND i might add the D/C tk didn't do a great install.
To protect your self from this ,if you have a leak from around the speedo pick-up body and the transmission--------- or you remove said p/u make the o-ring is ok .
Clean off with ether(starting fluid) air dry and coat with bath tub silicone caulk,install,will never leak again. And can be removed if needed years later
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
