Engine/Transmission (1998.5 - 2002) Transmission fluid
Engine/Transmission (1998.5 - 2002) 5 speed auto in a 2000
Engine/Transmission (1998.5 - 2002) hx35 w/ 16cm* too laggy???
The other day I checked the transmission fluid level in my truck and it was a bit low. I grabbed what I had on the shelf and topped it off. After the fact I checked to see what type fluid I should be using and the specs say ATF +4. The type I used was plain old ATF. :(
Should I be concerned? What's the difference between them?
Steve
Fluid
If you are still under warranty I would stick with the ATF 4.
I think it is a synthetic based fluid but not a true synthetic. :confused:
If you didn't use a lot I dont think you hurt anything.
go to www. diesel trans. com and get the answer.
