I have found that after regular service the trans. pan gasket (OEM gasket)A518 trans. seems to start weeping then leaking fluid after 4-5000 kms. Is there another brand that is more durable? Can I use a sealant on the gasket? Both sides, one side?? Any thoughts on this guys???
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar, Dual Shock Front Stabilizer, BD Injectors, 3" Mandrel bent exhaust, 16cm 'Hot End', Modest Pump Tweaks/Timed, K&N Air, Isspro Pyro,Tach,transmission Temp, Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots.
97,000 Kms.
97,000 Kms.
