Transmission gone again
Is there a way to reach DC Engineers?
They're Better? and they will Prove It?
Anyone experience their transmission going out without any warning signs. Driving without a load at 60 MPH on cruise and suddenly lose all forward gears. Reverse still worked, so it was a U-turn and drive backwards two mile to the barn. The first time was understandable,. . blown cooling line led to burnt transmission. Guessing the front pack is the problem area this time. Have been monitoring the TDR site for the last year and it seems this old 94 3500 has experienced every problem listed. Can't get things fixed long enough to sell it or trade it in. Feels good to vent though.
David Harris
Dave
get ahold of Bill K. His web address is kondolay@home.com He should be able to give you some advice or fix you up. He is one of the good guys.
95 slt 2wd auto 3. 5 gears -tst 230-605 plate- BD exhaust brake- primelok filter relocator- Bill Kondolay modified auto trans-98,000 miles. Who says six in a row don"t go? 95slt auto,bd exhaustbrake, TST 230/605 plate K&N airfilter, primelok fuelfilter relocator. Who say"s six in row don"t go?
Same thing happened to me. Overdrive failure. 94-95s had a problem with not enough lube going to the OD. A small part (retaining clip I think) would get hot enough to fail and allot the sun/planetary gear assembly to "crash". I replased mine with a new one from Dodge in '98 that had all current updated (improved lube, deep pan, extra oil line on valvebody). A good transmission shop could have saved me $1000 and the trans would work the same as the new one did.
My advise: Have a good trans shop do the rebuild and by a torque plate (for the fuel pump) and a torque converter (low stall from Dave Goerend) with what you will save over a dealer.
'94 3500 4x4, 205,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro gauges inplace of cupholder & Amsoil Air Filter & Lubes, AWOL silencer ring & intake boot. NRA member. Blue Ribbon Coalition member.
"Warrantee? We don't need no stinking warrantee!"
What brand and type of Trans fluid did you use? I'm taking a survey of all transmission fluid and gear oil used in Dodge Trucks. And the benefit or loss, as a result.
Thanks #ad
D McGrady 1996 Club Cab 6BTA 5. 9 12 Valve All Stock Except K&N and Wrangler A/T 305/70/16 136 K and going strong.
