transmission gurus - I need your input
I will be as brief as possible. I need to know what problems the following symptoms could be pointing to:
Every once in awhile, I notice a sort of sticking/popping feeling when shifting from 2nd to 3rd gear, like something is binding. I experienced a hard shifting problem after the SBC clutch was installed. I would say 99% of the shifting problem has pretty much gone away. I just started seeing fluid at the slot in the transmission, but I'm not sure whether it is oil or gear lube. I can't tell by smell, either. And the clutch is not slipping. Any input would be helpful.
Based upon my searches: I suspect the binding could be synchros or the pilot bearing. As for the leak I suspect either the rear main or the transmission input shaft seal. Those two are the only possible sources in this particular instance for leaking lube oil, correct?
