Gents; I am doing a makeover on my 98. 5 24v and with the transmission out and the exhaust off I noticed the transmission heater/cooler on the side of the block. After research- I think that in warm conditions a person while towing might benefit from bypassing the unit. In my service manual it says that overdrive will not work til 50 degrees and that is def not a problem in the summer within a min of startup. I think the heat calories added to the transmission line at the heater/ cooler should be bypassed during the heavy load time in summer. Anyone agree? Anyway- I am over-engineering a two guage system with before and aft temperature guages- and will test to see how much the cooler near the radiator lowers the coolant temp while towing 12,000 lbs and then how much the block side heater adds heat to the same fluid. Anyone else interested or has anyone tried anything like that?
