Engine/Transmission (1998.5 - 2002) transmission help
Engine/Transmission (1998.5 - 2002) Torque Converter Question
Engine/Transmission (1998.5 - 2002) vp44 testing
We have a 2001 dodge 4wd,built a new transmission for it,it shifts late any ideas it shifts around 3000 rpm it works goodit just shifts late. I put the heavier springs in the valve body it still didnt help. any ideas? thanks
WHAT heavier springs did you put in it?
Changing springs and pressures is a balancing action, so give us more info on what you did to it.
I agree with checking the throttle cable, it's very particular about being in the right spot. Just a couple teeth off and your shifts will be out in left field (or near red-line as the case may be). Good luck and if all else fails, get in touch with Bill K.
