1999 2500 QC 4x4
Only changes from stock currently are a sending unit on the fuel filter canister for a FP gauge and a FASS DDRP. Had a gauge going for transmission temp but that isn't working. Also rebuilt the battery terminal clamps, replaced the positive cable going between batteries with soldered ends and replacement clamps.
I have been chasing a transmission hunting issue for years. I can't remember when it began, if it was after
the battery cable rebuild or not, but my understanding is that it is caused by ground noise. In the past I cleaned all the grounds, battery tops, connectors etc, and new batteries also fixed the problem...for awhile.
It tends to hunt at 45-50 mph but is fine over 55. Unfortunately the roads around where I live have 45 MPH speed limits, really annoying!
This week we relocated G-100 because the bolt was frozen no matter what and my past efforts to get the nut off torqued it and it seemed like it was going to break. The move didn't improve the hunting, unfortunately.
I was reading up on alternator noise causing torque converter issues. MoparMan has an article about how to test the alternator to see if that's the source of the problem. We did replace the alternator before this issue appeared so there may be something there. I am going to pursue this testing.
What I'm wondering is, is there a poll or article listing all the known sources of noise that can cause this torque converter hunting issue?
