Hi grayw,
I had the same problems a month or so ago. It was the Throttle Position Sensor. From Dodge it cost $235, but from Cummins I got it for $138. 04 and that includes shipping. If you are interested, e-mail me and I can send you a sheet telling how to diagnose the TPS to see if it is bad or needs adjusted. Also do a search on TPS or Throttle Position Sensor and you will find a lot. Good Luck!
Jeremy Sweeten
1992 Dodge W-250 4x4
Cummins Diesel, Intercooled,
LE Package, 165K, AT, Warner Hubs, Dana 60HD 4,060 lb. front axle and Dana 70 6,084 lb. limited slip rear axle with 3. 54 gears, NPG 205 transfer case, 3" straight pipe(3. 5" Banks coming soon, still straight piped too), K&N air filter
http://home.earthlink.net/~sweeten1/index.htm
