mods
smarty tuner
deleted kitty
htb 62/12 (35psi / going to put up to 50 after new gasket and bolts)
flux 2 (100hp injectors)
fass 150gph
modded airbox
t&c cp3 stage1
dodge ram quadcab shortbed 2500 year 2005
my transmission was slipping in 2 gear. . changed oil today and found
grease/mud (metall and somthing) in bottom of oilpan
i can drive if i drive very slow in 2 but all other works fine.
(band adjustment was fine)
year ago i found a pice of a big locking ring but the slipping started
a month ago when i tried my new power with injectors and cp3.
ive read that dtt had a diy kit and price was
around 3500dollars (they told me it will hold 600-700hp)
but what kit can you recomend?
where do i get most bang for the buck?
i need to install it myself cause noone here in finland
wants/can build these trannys (not much of 48re here)
what parts do i need?
where should i order them? (to get most bang for the buck
smarty tuner
deleted kitty
fass 150gph
modded airbox
t&c cp3 stage1
