I have a 97 4x4 with the auto trans. I noticed a large puddle of pink fluid on the ground, looked underneath, but can't tell whether its coming from the trans or the t-case. I took it to a local 4x4 shop and they told me it was the rear seal on the trans and that they didn't work on transmissions. I took it to a 2nd shop and they told me that it was really leaking from the t-case and that they'd have to remove it to see why.
I know that some t-cases run transmission fluid, is that the case with our trucks? Also, is it possible that it really is a rear trans seal and that the transmission fluid is leaking from the trans into the t-case and then causing it to overflow and leak from the t-case? The reason I ask is that when I went to start up the truck after I noticed the puddle (the truck had been sitting for about 2wks), I put the truck in drive and it rolled backwards... making me think that the trans was low on fluid.
I know I should have checked the transmission fluid level at that point, but the trans kicked in right away and since the shop was only a couple of blocks away I went ahead and drove it to the shop.
Any thoughts/help/suggestions would be appreciated!!
Thanks,
Craig
Thanks,
Craig
