Ok, this was my fix for the infamous transmission cooler line fittings. The only place my lines had the plastic inserts was at the end of the 1/2" lines that were just before the cooler. The end of the hose at the cooler is attached the old fashoned way, hose slid over a ferrull manufactured in the steel line and hose clamped. I removed the plastic fittings with pliers. Once the fittins are removed, you will see you have cooler tubes from the trans with a slight ferrull built into the end. If you use a pliable hose, you can slide it over the end of the tube, clamp it and you are done. Due to the hydraulic hose I used, I cut the 1/2" line with a tubing cutter, installed a 1/2"brass compression fitting. I then removed the fitting leaving the compression sleave. (This will not come off!) I then cut the compression nut off with a dremel tool. This left the tubes with the brass sleaves as a stop for the hose clamp. I installed the hose over the sleave and clamped them. All done, no leaks, total cost $17. 00.
Charlie
Charlie
