Friday, on the way home I noticed a noise coming from my transmission. It sounds like a 'gear'noise or bearings that are loose. You know the noise you get from some older transmissions when you pull on the shift lever while in gear and when you turn it loose the noise quits? It's kind of like you are transfering the gear noise up through the shift lever into the cab. It does it all the time while in gear and does not change 'pitch' as speed changes. Pressing the clutch does not matter, 'throw out bearing'? Any ideas? This is the first concern I've had since purchasing. Now have 23. 7K miles. Thanks
Ron
Ron
