I noticed the bottom of my truck was oily last Thursday, the day after I filled it up with diesel. I usually work at getting it as full as possible and thought that I might have overfilled, causing my tank to vent diesel as I drove home. I didn't think of any oil leak until my auto trans started shifting weird. Monday morning, after driving the 52 miles to work, I looked under my truck while the engine was idling and saw a small metal line dripping red oil. I drove it another 16 miles to where I normally do my fabrication work and took the leaking line off the transmission and found two places where a plastic "keeper" had rubbed two holes. I replaced the line and put 7 quarts of fluid in and drove it another 170 miles that day. It started shifting in it's normal manner. Have I harmed the transmission? I drove another 130 miles today and put in another quart and got the level just above the safe mark. I'm pretty sure that I don't have any leaks now. I know I lost several quarts out of the trans when I was doing the line switch, so the trans wasn't near that low on fluid. I was hoping that the trans would last at least until I had it payed off, and then I could put the monthly payments into an escrow for a trans rebuild. I have 85,000 miles on it now, with two injector replacements, a problem with the fan clutch, and poor fuel economy. That's all the problems that I have had, so can't complain too much.
